Orbi WiFi 7 RBE973
Reply
R6700 Firmware update kills router
Re: R6700 Firmware update kills router
@RegisterAgain wrote:
I think I will just try hooking it up to my MacBook Pro with an ethernet cable to see if it recognizes it.
Wired is always best. Less chance of a failure when the wifi goes down. Not that that would ever happen!
Message 26 of 28
RegisterAgain
I successfully flashed the previous firmware, set up my network and everything seemed to be working with the exception of one site I have that is ipv6 only which only works part time. This seems to be a Netgear firewall issue that they won't fix, something about filtering ICMP I think. After a couple browsing sessions without losing internet access and because rolling back the firmware went smoothly, I went ahead and had the router update to the newest version. I have not noticed any problems as of yet, so hoping my issue was just a glitch in the previous update somewhere.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 27 of 28
RegisterAgain
Sad to say the dropouts have continued; sometimes just the 5GHz wireless and at other times worse with the complete disconnect of internet. I have messed with this for the last time, will use my old Apple Time Capsule.
Message 28 of 28
Top Contributors
Discussion stats
  • 27 replies
  • 9215 views
  • 8 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
