- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6700 V2: cannot access web portal after enabling HTTPS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yesterday I turned on the HTTPS option on the web portal now I cannot access the router using routerlogin.net.
What I have tried:
1. Tried wifi 2.4 or 5 Hz but not routerlogin.net page is not loading
2. Tried a wired connection but not routerlogin.net page is not loading
What's working:
1. Internet is working on 2.4 and 5 Hz both channels without issue.
2. Mobile app (nighthawk app) is connecting to the router locally successfully, However, the option to disable the HTTPS option is not available there.
I can reset the router and reconfigure that's not an issue but wanted to understand why it's not working when the manual says otherwise.
Thanks - Nishant
Looking for an answer
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6700 V2: cannot access web portal after enabling HTTPS.
did you try using its ip address?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I tried with the IP address but same issue.
additionally, I can ping the router successfully.
- Mark as New
- Bookmark
- Subscribe
- Permalink
could always factory reset and start over with https disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just curious why it is not working as described 🤔
