Orbi WiFi 7 RBE973
Reply
R6700v3 Slow wired connection after firmware update. WiFi ok
dyerpunk
i have 400mb/s cable internet.  I get 400mb/s if im connected directly to the modem, and through wifi when connected to the router.  However my wired connection through the router tops out at 200mb/s.  I've had the router for a few years and have always had this problem.  I rolled back the firmware previously and got the full 400mb/s with the old firmware.  Installing the latest firmware cuts my speed back down to 200mb/s on the wired connection.  Anyway to fix this without having to run outdated firmware?
Message 1 of 4
Guru
Re: R6700v3 Slow wired connection after firmware update. WiFi ok
when you reinstall the latest version, do a factory reset.
during the install process, make sure to leave qos, access control, parental controls, and traffic monitoring all disabled
Message 2 of 4
dyerpunk
Did all that and im still capped at 200mb on the wired connection
Message 3 of 4
Guru
what modem do you have?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 468 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
