Orbi WiFi 7 RBE973
Reply
R6700v3 - not showing a network to log into
sailcatmom
Follower
My Nighthawk Smart WIFI Router AC1750 isn't showing a light on under the 2.4 ghz network.  So the network isn't showing up on my phone or laptop in order to connect to the internet. Only lights are first two on left and a red light under "1".  Help please!
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
Guru
Re: R6700v3 - not showing a network to log into
have you checked to see if the 2.4ghz radio was disabled.
How do I enable or disable the WiFi radios on my NETGEAR router? | Answer | NETGEAR Support
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 364 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
