Orbi WiFi 7 RBE973
Reply
R6700v3
dcplumley
Tutor
R6700v3
after lastest update in firmware the router has to reset daily.
went back to V1.0.4.120_10.0.91 and now the issue still exists....
any thoughts?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 8
Accepted Solutions
Guru
Re: R6700v3
have you tried a simple factory reset of the router?
also make sure you have ipv6 enabled
Message 6 of 8
All Replies
Guru
Re: R6700v3
why are you resetting it.
What actual issue are you having thats causing you to reset?
Message 2 of 8
dcplumley
Tutor
Re: R6700v3
It keeps losing connection to the internet.
Message 3 of 8
Guru
Re: R6700v3
What modem/gateway is it connected to?
What firmware is on it?
When it "looses internet" what actually happens?
Do devices say "connected, no internet"? Do they not connect to the wifi at all? Does the ssid stop broadcasting?  do wired devices drop or just wireless?
What actually occurs? Details are key for troubleshooting. the less you tell us, the less we can help.
Message 4 of 8
dcplumley
Tutor
Re: R6700v3
Modem Netgear Cable 32x8 docsis3.1 - CM1000-1aznas for xfinity Comast, Cox
Can't control firmware on modem to my knowledge. done by comcast.
the local network is connect but it says no internet when look at app. also phone shows no internet. both android & iphones
there are no wired devices.
current firmware V1.0.4.120_10.0.91. one step back from current. When I installed the current was when the issue started.
When I connect to the router the internet status says good but on the app being on the local network states no internet. also can't connect remotely when this happens.
Message 5 of 8
Guru
Re: R6700v3
Message 6 of 8
dcplumley
Tutor
Re: R6700v3
Haven't done reset.
Ipv6 wasn't turned on. Turned it on.
Also going to see if tv streaming service effectived if goes out again. Haven't tested that
Message 7 of 8
dcplumley
Tutor
Re: R6700v3
Enabling ipv6 seems to have solve the issue.
Thanks.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1839 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
