Orbi WiFi 7 RBE973
Reply
R6900 drops internet connection for connected devices after short time on 2.5 wifi only, not 5.0
Richard513
Follower
Devices connected to my R6900 via 2.5 wifi loose internet connectivity after a short time.  The device still registers on the router and shows connectivity to the LAN.  But it has no Internet connectivity.  Switching the device to the 5.0 wifi connection allows Internet access which continues uninterrupted.  Rebooting the router restores connections and Interenet access at 2.5 wifi.  My firmware version is: V1.031316_1.15.  This problem has started after the router has been in service satisfactorly for a number of months.  How can I correct this problem?
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: R6900 drops internet connection for connected devices after short time on 2.5 wifi only, not 5.0
Hi Richard513,
Try changing the channel of the 2.4Ghz network. Also double check if the firmware is same with the latest one.
http://kb.netgear.com/000036747/R6900-Firmware-Version-1-0-1-16
Reset the router if the firmware is updated.
Message 2 of 3
All Replies
JamesGL
Master
Hi Richard513,
Message 2 of 3
JamesGL
Master
Hi Richard513,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5436 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
