Orbi WiFi 7 RBE973
Reply
R6900v2 - trying to connect a security camera to 2.4
DrJohnson93
I am trying to connect security cameras that require the 2.4 ghz.  I have tried connecting the Roku Indoor SE camera but it won’t connect.   HELP!
Message 1 of 9
Kitsap
Master
Re: R6900v2 - trying to connect a security camera to 2.4
"but it won't connect" is really, really, really, thin on details!
Some standard questions:
What is the brand name and model number of the modem/ONT that is connected to the internet upstream of your R6900v2?
What is the version number of the firmware currently installed on your R6900v2?  The latest, is not a version number.  Log in to the user interface and look in the upper right hand corner of the first page.
On your Wi-Fi configuration:
Do you have smart connect enabled?
Do you have 20/40 coexistence enabled?
What channel do you have set for the 2.4 GHz band?
For the 2.4 GHz band, what authentication method do you have set?  WPA2, WPA3, none...
How do you try to connect the camera to your Wi-Fi?  Through a web browser?  Through a mobile application?
Message 2 of 9
DrJohnson93
Brand name is Zhone XDSL 4 port
firmware on R9600v2 is V1.2.0.92-1.0.1
smart Connect is enabled
20/40 coexistence is enabled
channel for 2.4 ghz is Auto (10)
authenitication method is WPA2
I was trying to use mobile app with smart phone to connect
Message 3 of 9
Kitsap
Master
20/40 coexistence is enabledt
Recommend you disable smart connect.  This will give you a different and distinct SSID for both the 2.4 GHz band and the 5 GHz band.
Recommend you disable 20/40 coexistence.  In general, items in the IoT world cannot take advantage of or need the 40 MHz wide channel.
Recommend you manually set the 2.4 GHz channel to 6 or 11.  The auto function can interact poorly with some IoT devices.
Make certain you have turned off the cell data connection on your smart phone and connect to the 2.4 GHz Wi-Fi band before you start your camera configuration application.
The authentication method is fine at WPA2.  If you still fail to connect to your camera, you might try setting this to NONE on a temporary basis.  Check if you can connect.  Do not leave it at NONE for long term.
Message 4 of 9
Kitsap
Master
As an addendum.  Your Zhone XDSL 4 port is a combination modem/Wi-Fi router.  Do you have it configured in bridge mode so as not to interfere with the routing function of your R6900v2?
Message 5 of 9
DrJohnson93
No.   I honestly have no idea how to do that.
Message 6 of 9
Kitsap
Master
You do not want two routers connected to the same local network with both of them attempting to perform routing functions.  This configuration is referred to as double NAT and here is just the start of why it is bad:  https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
One option is to disable the router function of your Zhone XDSL.  This is often referred to as bridge mode or modem only mode.  You are going to have to do your own research to accomplish this task on your Zhone XDSL.  It is beyond the scope of this Netgear forum.
A second option is to configure your R6900v2 as a wired access point and connect it via Ethernet cable to your Zhone XDSL router.  This disables some of the functions of the R6900v2 as described here:  https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
Here is a description of how to set your R6900v2 to operate as an access point.  https://kb.netgear.com/30025/I-m-setting-up-my-Nighthawk-router-for-the-first-time-how-do-I-set-it-t...
Message 7 of 9
DrJohnson93
Thank you!  Those suggestions worked!
Message 8 of 9
Kitsap
Master
It would be helpful to others, if you clearly identified which of "Those suggestions" worked.  Then mark this thread as resolved.
Copy and paste works fine in this format.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1095 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
