- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 Nightnawk | Getting half of my Spectrum subscribed speed when hardwired through router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everyone,
I have an R7000 Nighthawk. I have the 400Mbps package from Spectrum, and when my desktop computer is hardwired into their Modem (EN2251) I am receiving 450Mbps or higher. The issue is that when I setup my network as ISP>Modem>Router>etc I am receiving around 270Mbps. This is the speed I am receiving when hardwired into the router, not wireless.
This issue has persisted through updating firmware (currently on the latest (V1.0.11.134_10.2.119), removing QoS & Traffic Meter, enabling IPv6, and removing all port forwarding. I bought a different an Arris SurfBoard 588200 Modem and had Spectrum enable that device but the connection was so volatile (speeds ranging from 100 to 370Mbps, constantly changing) that I swapped back.
I'm at the end of my rope. I am unsure what to do next and am requesting assistance. Please someone tell me there is an fix for this nonsense.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you ever factory reset and test if from the defaults?
problem with having qos/access control/traffic monitoring/parental controls enabled is that they disable cut through forwarding. Its the service needed to hit gigabit speeds. And I've seen it get disabled because those services were on but not get re-enabled when the services were disabled. So try a factory reset. Test it from its default speeds.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 Nightnawk | Getting half of my Spectrum subscribed speed when hardwired through router
@plemans First off - I want to say thank you, as I have seen many of your other posts on other threads with similar issues. I have yet to Factory Reset the device. Would you suggest going back to original / changing firmware prior to Factory Resetting? Please note that I am on the latest Firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try it on the version you're on first. there's been a lot of firmware updates since the version that we (on here) consider the most stable. And for most people, it works fine.
What actual version number are you on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I loaded v134 the other day and is working so far:
@Demicos wrote:
Hello everyone,
- Mark as New
- Bookmark
- Subscribe
- Permalink
(V1.0.11.134_10.2.119) is what it has at the top right of my Router's webpage
I had ot download that version from Netgear's site as it wouldn't update automatically to it for some reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how the factory reset goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it worked!
A backup is always a good thing to have for next time 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you save a configuragion backup, it is also a good idea to annotate in the file name the firmware version installed when the backup was made. In general it is not good/succesful practice to restore a backup to a different firmware version than was installed when it was saved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:...problem with having qos/access control/traffic monitoring/parental controls enabled is that they disable cut through forwarding. Its the service needed to hit gigabit speeds....
I've noticed that even without gigibit speeds (I'm running 100Mbps) allowing cut through forwarding reduces jitter and improves my VOIP quality. I'm wondering if also turning off WMM (which is a form of QoS) would enable cut through forwarding on wireless traffic and reduce jitter.
