Orbi WiFi 7 RBE973
Reply
R7000 OpenVPN latency,ping,slow
qwerty77
Hi all,
When I'm connecting via VPN to my home network, everything is very slowly and laggy.
My router has IP address 192.168.2.1 and I see this rule below in the client log and it seems like that's the cause, but how to fix it?
Tue Nov 07 12:04:17 2017 us=566872 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.2.0
Client log:
Tue Nov 07 12:03:53 2017 us=799247 OpenVPN 2.4.4 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Sep 26 2017
Tue Nov 07 12:03:53 2017 us=799247 Windows version 6.2 (Windows 8 or greater) 64bit
Tue Nov 07 12:03:53 2017 us=799247 library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10
Enter Management Password:
Tue Nov 07 12:03:53 2017 us=799247 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Tue Nov 07 12:03:53 2017 us=799247 Need hold release from management interface, waiting...
Tue Nov 07 12:03:54 2017 us=280937 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Tue Nov 07 12:03:54 2017 us=390209 MANAGEMENT: CMD 'state on'
Tue Nov 07 12:03:54 2017 us=390209 MANAGEMENT: CMD 'log all on'
Tue Nov 07 12:03:55 2017 us=xx3595 MANAGEMENT: CMD 'echo all on'
Tue Nov 07 12:03:55 2017 us=848098 MANAGEMENT: CMD 'hold off'
Tue Nov 07 12:03:55 2017 us=861589 MANAGEMENT: CMD 'hold release'
Tue Nov 07 12:03:55 2017 us=862077 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Nov 07 12:03:55 2017 us=946021 LZO compression initializing
Tue Nov 07 12:03:55 2017 us=946021 Control Channel MTU parms [ L:1654 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Tue Nov 07 12:03:55 2017 us=946021 Data Channel MTU parms [ L:1654 D:1450 EF:122 EB:411 ET:32 EL:3 ]
Tue Nov 07 12:03:55 2017 us=946021 Local Options String (VER=V4): 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
Tue Nov 07 12:03:55 2017 us=946021 Expected Remote Options String (VER=V4): 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
Tue Nov 07 12:03:55 2017 us=946021 TCP/UDP: Preserving recently used remote address: [AF_INET]145.xx.xx.xx:xxxxx
Tue Nov 07 12:03:55 2017 us=946021 Socket Buffers: R=[65536->65536] S=[64512->64512]
Tue Nov 07 12:03:55 2017 us=946021 UDP link local: (not bound)
Tue Nov 07 12:03:55 2017 us=946021 UDP link remote: [AF_INET]145.xx.xx.xx:xxxxx
Tue Nov 07 12:03:55 2017 us=946021 MANAGEMENT: >STATE:1510052635,WAIT,,,,,,
Tue Nov 07 12:03:58 2017 us=925606 MANAGEMENT: >STATE:1510052638,AUTH,,,,,,
Tue Nov 07 12:03:58 2017 us=925606 TLS: Initial packet from [AF_INET]145.xx.xx.xx:xxxxx, sid=bcf2ade2 88fb8afb
Tue Nov 07 12:03:59 2017 us=269180 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
Tue Nov 07 12:03:59 2017 us=269180 VERIFY OK: depth=0, C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
Tue Nov 07 12:03:59 2017 us=376138 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Tue Nov 07 12:03:59 2017 us=376138 [netgear] Peer Connection Initiated with [AF_INET]145.xx.xx.xx:xxxxx
Tue Nov 07 12:04:00 2017 us=423049 MANAGEMENT: >STATE:1510052640,GET_CONFIG,,,,,,
Tue Nov 07 12:04:00 2017 us=423049 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
Tue Nov 07 12:04:05 2017 us=493859 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
Tue Nov 07 12:04:11 2017 us=8668 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
Tue Nov 07 12:04:16 2017 us=521258 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
Tue Nov 07 12:04:17 2017 us=566872 PUSH: Received control message: 'PUSH_REPLY,route 192.168.2.0 255.255.255.0,route-delay 5,route-gateway dhcp,ping 10,ping-restart xx,route 192.168.2.1 255.255.255.0 192.168.2.1'
Tue Nov 07 12:04:17 2017 us=566872 OPTIONS IMPORT: timers and/or timeouts modified
Tue Nov 07 12:04:17 2017 us=566872 OPTIONS IMPORT: route options modified
Tue Nov 07 12:04:17 2017 us=566872 OPTIONS IMPORT: route-related options modified
Tue Nov 07 12:04:17 2017 us=566872 Data Channel MTU parms [ L:1590 D:1450 EF:58 EB:411 ET:32 EL:3 ]
Tue Nov 07 12:04:17 2017 us=566872 Outgoing Data Channel: Cipher 'AES-128-CBC' initialized with 128 bit key
Tue Nov 07 12:04:17 2017 us=566872 Outgoing Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Nov 07 12:04:17 2017 us=566872 Incoming Data Channel: Cipher 'AES-128-CBC' initialized with 128 bit key
Tue Nov 07 12:04:17 2017 us=566872 Incoming Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Nov 07 12:04:17 2017 us=566872 interactive service msg_channel=552
Tue Nov 07 12:04:17 2017 us=566872 ROUTE_GATEWAY 10.55.51.1/255.255.255.0 I=5 HWADDR=00:1f:b5:23:93:6a
Tue Nov 07 12:04:17 2017 us=566872 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Tue Nov 07 12:04:17 2017 us=566872 open_tun
Tue Nov 07 12:04:17 2017 us=566872 TAP-WIN32 device [NETGEAR-VPN] opened: \\.\Global\{F57EFFD5-04F6-4A46-943B-4C727D6C5BD6}.tap
Tue Nov 07 12:04:17 2017 us=566872 TAP-Windows Driver Version 9.21
Tue Nov 07 12:04:17 2017 us=566872 TAP-Windows MTU=1500
Tue Nov 07 12:04:17 2017 us=566872 Successful ARP Flush on interface [16] {F57EFFD5-04F6-4A46-943B-4C727D6C5BD6}
Tue Nov 07 12:04:19 2017 us=804970 Extracted DHCP router address: 192.168.2.1
Tue Nov 07 12:04:22 2017 us=71377 TEST ROUTES: 1/1 succeeded len=1 ret=1 a=0 u/d=up
Tue Nov 07 12:04:22 2017 us=71377 MANAGEMENT: >STATE:1510052662,ADD_ROUTES,,,,,,
Tue Nov 07 12:04:22 2017 us=71377 C:\Windows\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.0 192.168.2.1
Tue Nov 07 12:04:22 2017 us=71377 ROUTE: route addition failed using service: The parameter is incorrect. [status=87 if_index=16]
Tue Nov 07 12:04:22 2017 us=71377 Route addition via service failed
Tue Nov 07 12:04:22 2017 us=71377 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Tue Nov 07 12:04:22 2017 us=71377 Initialization Sequence Completed
Tue Nov 07 12:04:22 2017 us=71377 MANAGEMENT: >STATE:1510052662,CONNECTED,SUCCESS,,145.xx.xx.xx,xxxxx,,
Show Status (on client):
Tue Nov 07 12:03:53 2017 OpenVPN 2.4.4 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Sep 26 2017
Tue Nov 07 12:03:53 2017 Windows version 6.2 (Windows 8 or greater) 64bit
Tue Nov 07 12:03:53 2017 library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10
Tue Nov 07 12:03:53 2017 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Tue Nov 07 12:03:53 2017 Need hold release from management interface, waiting...
Tue Nov 07 12:03:54 2017 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Tue Nov 07 12:03:54 2017 MANAGEMENT: CMD 'state on'
Tue Nov 07 12:03:54 2017 MANAGEMENT: CMD 'log all on'
Tue Nov 07 12:03:55 2017 MANAGEMENT: CMD 'echo all on'
Tue Nov 07 12:03:55 2017 MANAGEMENT: CMD 'hold off'
Tue Nov 07 12:03:55 2017 MANAGEMENT: CMD 'hold release'
Tue Nov 07 12:03:55 2017 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Nov 07 12:03:55 2017 LZO compression initializing
Tue Nov 07 12:03:55 2017 Control Channel MTU parms [ L:1654 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Tue Nov 07 12:03:55 2017 Data Channel MTU parms [ L:1654 D:1450 EF:122 EB:411 ET:32 EL:3 ]
Tue Nov 07 12:03:55 2017 Local Options String (VER=V4): 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
Tue Nov 07 12:03:55 2017 Expected Remote Options String (VER=V4): 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
Tue Nov 07 12:03:55 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]145.xx.xx.xx:xxxxx
Tue Nov 07 12:03:55 2017 Socket Buffers: R=[65536->65536] S=[64512->64512]
Tue Nov 07 12:03:55 2017 UDP link local: (not bound)
Tue Nov 07 12:03:55 2017 UDP link remote: [AF_INET]145.xx.xx.xx:xxxxx
Tue Nov 07 12:03:55 2017 MANAGEMENT: >STATE:1510052635,WAIT,,,,,,
Tue Nov 07 12:03:58 2017 MANAGEMENT: >STATE:1510052638,AUTH,,,,,,
Tue Nov 07 12:03:58 2017 TLS: Initial packet from [AF_INET]145.xx.xx.xx:xxxxx, sid=bcf2ade2 88fb8afb
Tue Nov 07 12:03:59 2017 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
Tue Nov 07 12:03:59 2017 VERIFY OK: depth=0, C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
Tue Nov 07 12:03:59 2017 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Tue Nov 07 12:03:59 2017 [netgear] Peer Connection Initiated with [AF_INET]145.xx.xx.xx:xxxxx
Tue Nov 07 12:04:00 2017 MANAGEMENT: >STATE:1510052640,GET_CONFIG,,,,,,
Tue Nov 07 12:04:00 2017 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
Tue Nov 07 12:04:05 2017 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
Tue Nov 07 12:04:11 2017 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
Tue Nov 07 12:04:16 2017 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
Tue Nov 07 12:04:17 2017 PUSH: Received control message: 'PUSH_REPLY,route 192.168.2.0 255.255.255.0,route-delay 5,route-gateway dhcp,ping 10,ping-restart xx,route 192.168.2.1 255.255.255.0 192.168.2.1'
Tue Nov 07 12:04:17 2017 OPTIONS IMPORT: timers and/or timeouts modified
Tue Nov 07 12:04:17 2017 OPTIONS IMPORT: route options modified
Tue Nov 07 12:04:17 2017 OPTIONS IMPORT: route-related options modified
Tue Nov 07 12:04:17 2017 Data Channel MTU parms [ L:1590 D:1450 EF:58 EB:411 ET:32 EL:3 ]
Tue Nov 07 12:04:17 2017 Outgoing Data Channel: Cipher 'AES-128-CBC' initialized with 128 bit key
Tue Nov 07 12:04:17 2017 Outgoing Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Nov 07 12:04:17 2017 Incoming Data Channel: Cipher 'AES-128-CBC' initialized with 128 bit key
Tue Nov 07 12:04:17 2017 Incoming Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Nov 07 12:04:17 2017 interactive service msg_channel=552
Tue Nov 07 12:04:17 2017 ROUTE_GATEWAY 10.55.51.1/255.255.255.0 I=5 HWADDR=00:1f:b5:23:93:6a
Tue Nov 07 12:04:17 2017 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Tue Nov 07 12:04:17 2017 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.2.0
Tue Nov 07 12:04:17 2017 open_tun
Tue Nov 07 12:04:17 2017 TAP-WIN32 device [NETGEAR-VPN] opened: \\.\Global\{F57EFFD5-04F6-4A46-943B-4C727D6C5BD6}.tap
Tue Nov 07 12:04:17 2017 TAP-Windows Driver Version 9.21
Tue Nov 07 12:04:17 2017 TAP-Windows MTU=1500
Tue Nov 07 12:04:17 2017 Successful ARP Flush on interface [16] {F57EFFD5-04F6-4A46-943B-4C727D6C5BD6}
Tue Nov 07 12:04:19 2017 Extracted DHCP router address: 192.168.2.1
Tue Nov 07 12:04:22 2017 TEST ROUTES: 1/1 succeeded len=1 ret=1 a=0 u/d=up
Tue Nov 07 12:04:22 2017 MANAGEMENT: >STATE:1510052662,ADD_ROUTES,,,,,,
Tue Nov 07 12:04:22 2017 C:\Windows\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.0 192.168.2.1
Tue Nov 07 12:04:22 2017 ROUTE: route addition failed using service: The parameter is incorrect. [status=87 if_index=16]
Tue Nov 07 12:04:22 2017 Route addition via service failed
Tue Nov 07 12:04:22 2017 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Tue Nov 07 12:04:22 2017 Initialization Sequence Completed
Tue Nov 07 12:04:22 2017 MANAGEMENT: >STATE:1510052662,CONNECTED,SUCCESS,,145.xx.xx.xx,xxxxx,,
Ping WAN results:
Ping LAN results:
Need I change / enable / disable something?
Thanks for help!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Accepted Solutions
qwerty77
Re: R7000 OpenVPN latency,ping,slow
Topic can be closed. Setting the TUN and TAP Servicetype to TCP instead of UDP gives much better performance.
Ping results are now around the 11-12 ms.
Message 2 of 3
All Replies
qwerty77
Message 2 of 3
KristinaS
Apprentice
usualy udp is faser. i am using tun and udp.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5407 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
