- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 QOS Slows Down 200mbps Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Comcast HighSpeed internet. I upgraded to their 200mbps speed. I did have 100mbps. I had dynamic qos setup for the 100mbps connection and never had a problem. But with the qos enabled with 200mbps I can only get 117mbps. With it disabled I get 241 mbps down. Is there a way to keep it enabled and still max out my connection if my pc is the only device downloading at the moment?
On my network I use 3 Rokus, 3 Smart Phones, an XBOX, a Desktop PC, A Notebook, A Netbook, and guest devices (up to 3 sometimes)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
QoS is pretty CPU intensive and it only comes into play when your Internet connection is congested. Unless you are making full use of your Internet connection, you should turn off QoS.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 QOS Slows Down 200mbps Connection
@waresoft wrote:I have Comcast HighSpeed internet. I upgraded to their 200mbps speed. I did have 100mbps. I had dynamic qos setup for the 100mbps connection and never had a problem. But with the qos enabled with 200mbps I can only get 117mbps. With it disabled I get 241 mbps down. Is there a way to keep it enabled and still max out my connection if my pc is the only device downloading at the moment?
Have you told the qos about the new 200mb speed ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
