Orbi WiFi 7 RBE973
Reply
R7000 net gear router
novel
I cannot get my netgear R7000 router set up, the app cannot find it and when I login to it there is no setup wizard.
Is there anyway I can set it up after I log into it?
The modem and router has been rebooted numerous times with no luck, I am operating with the default wifi.
If anybody can help me it will be greatly appreciated.
Message 1 of 2
Guru
Re: R7000 net gear router
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to a web browser and walk thru the setup wizard at192.168.1.1. This time write down all important information for safe keeping later on.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 568 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
