Orbi WiFi 7 RBE973
Reply
R7000 openVPN error
dizzydevil
R7000 openVPN error
The OpenVPN application was updated through Android store recently.  Since then, I'm unable to connect and it throws an error saying I have an invalid certificate.  I deleted the profile and reinstalled the certificate from the router again but the error returns.  Do we need an update on the router as well for the VPN to work again?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
dizzydevil
Re: R7000 openVPN error
yes the update fixed the issue. Thank you
Message 4 of 4
All Replies
dizzydevil
The error is:
OpenVPN server certificate verification failed : mbed TLS: SSL read error : X509 - Certificate verification failed, eg CRL, CA or signature check failed.
Message 2 of 4
JamesGL
Master
Hi dizzydevil,
What is the software version of you OpenVPN client software for Android. The latest one should resolve the problem.
Message 3 of 4
dizzydevil
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3604 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
