Orbi WiFi 7 RBE973
Reply
R7000 router will only connect to one device at a time (Verizon fios WiFi)
Apallozzi
I just purchased a R7000 nighthawk router.  I have Verizon fios as my isp.  I have two computers hard wired to the router.  They are working fine.  Unfortunately, I can only connect one item to the WiFi at a time.  All outer devices appear to be connected to the router, but they have no access to the internet.  Only the first connected device gets internet access.  What can I do to fix this?
Message 1 of 6
Guru
Re: R7000 router will only connect to one device at a time (Verizon fios WiFi)
There any wifi radios on the ISP modem?
Message 2 of 6
GregGreg
Star
@Apallozzi
I would suggest checking the IP network addressing. If Verizon uses a private IP network with an address of 192.168.1.0/24, you must use a different private network on the R7000 (e.g. 192.168.20.0/24).
If your internet IP address starts with 192.168.1.xxx (where xxx is value from 1 to 254) - this is the problem described above.
Message 3 of 6
Apallozzi
It looks like both my IP and my router have addresses starting with 192.168.1.  So you are saying I need a new address for the router?  How do I change that?
Btw, I called Netgear and they had me upchange my firmware.  That helped me get a few more devices on at a time, but I still can't get all of them on at once.
Message 4 of 6
GregGreg
Star
@Apallozzi
Below are two general links for re-addressing IP network on R7000:
https://kb.netgear.com/24088/How-do-I-change-the-LAN-TCP-IP-settings-on-my-Nighthawk-router
https://setuprouter.com/router/netgear/r7000/ip-address.htm
I would try to do it like this:
Select ADVANCED > Setup > LAN Setup.
       In the IP Address field, type the IP address:192.168.5.1
       In the IP Subnet Mask, type the subnet mask of the router: 255.255.255.0
       In the RIP Direction, select: Both
       In the RIP Version list, select: Disabled
       Leave checked mark: Use Router as DHCP Server
           Starting IP Adress: 192.168.5.10
           Ending IP Adress: 192.168.5.254
After saving the configuration, the router will reboot (or you to do it).
Then power off/power on (or reconnect network cabel/ recoonect WiFi) all devices connected to Router (should receive new IP address starts from range 192.168.5.10 to 192.168.254) (Verizon devices do not restart)
Keep in mind:
Before the change, you will connect to the router at: http://192.168.1.1
After changing the configuration, you will connect to the router at: http://192.168.5.1
Each factory reset will return to network addressing: 192.168.1.0/24
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 950 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
