Orbi WiFi 7 RBE973
Reply
R7000
michellerchild
Follower
R7000
How do you login to the router if the original owner passed away and you don't know his login info or security question answers? I need to login to change the router from 5 to 2.4ghz to setup a security camera.
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 2
Samual_ch1
Re: R7000
You can return the router to its factory settings. Use the end of a paper clip or a similar object to press and hold the Reset button on the back of the router for at least seven seconds. The router resets and returns to the factory configuration settings.
You can login into the router UI by going to routerlogin.net and set up the router as if it were new.
Model: R7000|AC1900 Smart WIFI Router
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 490 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
