do2blehelix's avatar
do2blehelix
Follower
Feb 16, 2024
R7300 firmware config after 1.0.0.68?
mikeebee
https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Anyone-find-stable-R7300-firmware-config-after-1-0-0-68/m-p/2364216
I upgraded to 1.0.0.74_1.0.29 and faced the dreaded issue of network drops, but only with the 5Ghz connection. I had separated the networks (2.4g, 5g) as I wanted to see where the issue was. The 2.4Ghz worked fine most times and I was using it for IOT devices. The 5Ghz network was nightmare.
I had tried altering the 5Ghz channel from 153 to the rest. Some of them held onto for longer before network drops, but all 3 digit channels dropped connections (I did not test the 2 digit channels 36-48 though)
Didn't find much information on the network drops except generic stuff.
Thank you, Thank You, THANK YOU so very much for mentioning which version worked for you.
I immediately downgraded to 1.0.0.68. Fingers crossed now! đŸ€ž
No RepliesBe the first to reply
