Orbi WiFi 7 RBE973
Reply
R8000 firmware upgrade
rorton
The latest R8000 firmware upgrade states that iTunes Server is not supported. How does that affect iTunes?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Accepted Solutions
Guru
Re: R8000 firmware upgrade
No, it usually hosts on the pc/laptop its installed on. Unless you specifically set it up for a server to run on the router
Message 4 of 4
All Replies
Guru
if your not using itunes server off the router, it doesn't.
If you are, then don't upgrade.
Message 2 of 4
rorton
Hi plemans,
I use iTunes for backing up/syncing my iPhone. Does iTunes use the iTunes server on the router?
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1325 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
