- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8500 Slow Wifi v1.0.0.56_1.0.28
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to troubleshoot slow wifi speeds. Anyone experience trouble with the latest firmware update?
Speedtest hardwired:
Speedtest wireless [2.4Ghz & 5Ghz show about the same speed] (from iPhone 6) approximately 3 feet from router:
Wireless Settings:
2.4Ghz - Enabled
WPA2-PSK[AES]
Channel 4
Mode: Up to 1000Mbps
5Ghz - Enabled
Smart Connect - Enabled
WPA2-PSK[AES]
Channel 44 + 153
Mode: Up to 2165 Mbps
Advanced Wireless Settings:
Beamforming: Disabled and Enabled, no difference.
Suggestions for troubleshooting?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Indeed my router was replaced, however, this didn't solve the problem. A beta firmware ultimately resolved the problem.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8500 Slow Wifi v1.0.0.56_1.0.28
I've actually further isolated this to the 2G wifi band only. Connection to the 5G is extremely fast.
5G connection speed:
Contacted support... Suggested downgrading to v1.0.0.52_1.0.26. This had no affect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm replacing my old router right now.
I will check this too!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@travelton wrote:Trying to troubleshoot slow wifi speeds. Anyone experience trouble with the latest firmware update?
Wireless Settings:
2.4Ghz - Enabled
WPA2-PSK[AES]
Channel 4
5Ghz - Enabled
WPA2-PSK[AES]
Channel 44 + 153
2.4ghz, 1,6, or 11. You are creating issues using an overlappong channel for yourself and possibly your neighbours (Channel 4). Try higher channels (150ish) for 5ghz. Ensure WMM is enabled. on the router and your client. If you are running .ac ensure your client has VHT checked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@netwrks Using a wifi discovery tool, to discover APs in my area, I selected channel 9, as there are no APs broadcasting on that channel. No change in the slow speeds.
I believe this is a software issue on the R8500. I can set up my older Netgear WNDR4500 to broadcast the same 2.4Ghz signal parameters. The WNDR4500 results in consistent 30-40Mbps down, 30-40Mbps up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm getting <1Mbps though my 5Ghz is pretty fine.
I have tried hard reset after updating to the latest firmware.
Tried changing channels as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Replaced my AC87u with the R8500 and I am quite pleased except with my upload speeds.
Mine are not a bad as the others in this thread but it is still a considerable drop over the Asus.
LAN Ping 1 +900 download +900 upload
WLAN Ping 3 +450 download -125 upload
On Asus my Upload and Download we pretty much equal.
Also I noticed my Asus AC68u WLAN bridges report a link speed of 877.5mbps whereas on Asus it was 1300mbps. The AC87u have a link speed of +1020 but the ping nearly doubles to 5.
Every device seems to Capped at ~125 upload on 5ghz
QOS is disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@agoetz5201 Do you have the latest firmware installed on the router?
If you do, I suggest that you contact support for further troubleshooting on the speed issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My speeds were pretty abismal when I was trying to use one ssid. I split everything out (one for 2.4G, two for 5G) and the speeds have been much better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for that input @ChrisRogers91
Are you saying that SmartConnect is not working properly?
If that's the case, I recommend that you contact our support team.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well after several weeks, Netgear finally agreed to replace my unit. Received the replacement and the 2G network is still crap. Timeouts, slow speeds, and random drops.
At this point, there's nothing I can do. Can't return the device. I pretty much just took $400 and threw it out the window.
Lesson learned... Don't ever buy a device until it has sufficient time on the market and there are no negative reports within forums.
Shame on you Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@travelton I apologize for any inconvenience this may have caused you.
I see that your case is being reviewed by our engineering department.
I will make a follow-up and let you know any update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know some people say extended warranties are a waste. But in my opinion, not a waste on wireless routers. I've returned one 8500 already. If the next firmware doesn't fix much then it's going back as well for a different brand. This router was rushed to the market too soon. It's sad when your nervous to update a firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have found firewmare versions 1.0.0.56 and 1.0.0.52 to have issues with both 2.4Ghz and 5Ghz bands. Firmware 1.0.0.42 has been the most stable for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@travelton & @bkron08 Looks like your routers have been replaced.
Let us know if you need further help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the confirmation @travelton
