- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R900 slower wired speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Folks,
Setup:
CM1000 Modem-->R9000 Nighthawk router
R9000 has QoS disabled, running firware V1.0.5.26
400Mbps internet service
Problem:
On the R9000, I am getting download speeds of 470+ Mbps when using the speedtest mechanism. This aligns with my Internet plan, yet when I connect via CAT6 directly to the router, I am getting ~200 Mbps (about half like other posts has mentioned). This observed speed has been replicated on two different machines.
This is similar to many other posts, and I was curious if there was more recent information on the solution, including firmware (before I attempt previous versions). Is firmware truly the cause here, or is there some configuration interfering?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R900 slower wired speed
A quick thing to try is a factory reset and reinstall. don't install using a backup configuration and make sure to leave qos, parental controls, access controls, and traffic monitoring off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks @plemans, is this to see if a configuration is perhaps the problem? I do have some reserved addresses I'd like to keep, and can back that up, and the config if this doesn't work.
Are there other configs to check first, before going through this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Things to check try first?
1. the cable.
2. disable all those services I mentioned and reboot the router. Sometimes this fixes it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I should have mentioned that in the original post. So far I have tried:
- Unique cables, and machines, directly conected to the router (same problem)
- Disabling QoS, parental controls, traffic meter (same problem)
- Restoring the factory settings (as @plemans suggested) (same problem)
- I have rebooted several times recently after a speed increase from my Ineternet provider, and firmware updates to the router (same problem)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also make sure access control is disabled.
You can always try downgrading a version with the factory reset again.
