- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R9000 Nighthawk X10 AD2700 Smart WiFi Unable to login into Router after attempting an update
- Mark as New
- Bookmark
- Subscribe
- Permalink
I attemped and update from mt iPhone using the Nighthawk app and after the attemped update the Router is unable to function. No WiFi conection or ethernet conection. Anybody experince this issue and if so is there a fix for it? Thanks,RD_R9000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R9000 Nighthawk X10 AD2700 Smart WiFi Unable to login into Router after attempting an update
On the forum, we usually recommend users update via a hardwired connection. Reason why is if we see issues with firmware updates, its when its done over the app or over wifi.
things you can try?
Try factory resetting. Push and hold reset for up to 30 seconds while powered on.
doesn't work?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again and be blessed…
RD_R9000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good luck!
Take your time with both tftp/nmrpflash. Both are sensitive to timings and spelling. So if it doens't work the first time, check your work and try again
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
