Orbi WiFi 7 RBE973
Reply
Replacing Nighthawk R7900 AC3200 to a R8000P AC4000
Baracuda1974
Follower
Good day to us all and apologize if this question has been answered.
I have a R7900 and going to have it replaced to a R8000P, my question to the group is there a way to port over setting and device list to the new router without the need to add each single device back to the new router?
Message 1 of 3
Guru
Re: Replacing Nighthawk R7900 AC3200 to a R8000P AC4000
There isn't. You'll need to setup the new router from scratch.
Message 2 of 3
Guru
Not sure why you'd want to go from the R7900 to the R8000.
the R7900 hardware wise is a R8000 with 256qam disabled on the 2.4ghz band.
Basically the same device.
And its 7 years old.
I'd be looking at something a little newer.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 674 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
