- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router siifling internet connection R6900p
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am experiencing a loss of connection speed both with Wifi and hardwire. I am recieving 6mbps to my router but only getting 2.7mbps at best from the router. I have verified with a different router that the incoming speed is correct. I have reset the router and it did not change anything. Firmware Version V1.3.1.64_10.1.36, Windows 10, Any help is appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So with a little testing I found that it was not the firmware version(Sorry Netgear not your fault). The problem as far as I can tell from playing with the different versions is that the QoS must be speedtested and then click apply at the top in order for the router to accept the faster speed. I would think that it would recognize this by itself. So, if you have recently increased your internet speed and are not getting it from your Nighthawk try logging into your router and going to QoS and running a speedtest and then clicking apply at the top. I may be wrong, but now my router is working with the faster speed. Let me know if this works for you.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router siifling internet connection R6900p
I found a fix. I reverted to an old version of the firmware and now I am getting the proper speeds. The firmware version is R6900P-V1.3.1.44_10.1.23.chk.
So is Netgear going to fix the updated firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
