- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
So I purchased this router and I think I got screwed over. No internet No valid IP Please Help
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I purchased this router XR500 and I think I got screwed over.When First turned it on I Had a flashing red ligjt Reset the device a couple time then got a solid red light while having ethernet connected to PC did a troubleshoot by windows10 and also reset the device and now Its at a blinking white like No internet the entire time and When troubleshooting with blink white light I get a error "no valid IP address. also no wireless signal is being detected on any of my devices So I cant update firmware as reccomended for the red light issue that I some how got passed anyone hurd of this issue and what the fix might be. I See theres a couple USB ports on the device can I update firmware by usb?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I'd try to do.
1. disconnect from the xfinity.
2. factory reset the XR. Push and hold reset for 7-15 seconds
3. hardwire a pc/laptop into the XR after it finishes rebooting from the reset.
4. try to set it up using the wired in device. You can either use the default 192.168.1.1 or the routerlogin . net address
See if you can connect to it that route. The goal is to first see if the router is working fine. If it is, then we'll get your gateway setup properly
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: So I purchased this router and I think I got screwed over. No internet No valid IP Please Help
Are any of the other lights on?
What modem/gateway is it connecting to?
Did you factory reset? (push and hold reset for 7-15 seconds while powered on)
You can't update using usb on it but you can push firmware using tftp. I'd check the other detals first before going that route.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, for future issues, try in the forum for your device. DumaOS is a seperate OS and their forum is better suited to helping with it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No other light unless I plug in the ethernet cable.
Factor reseted to get the device from being a solid red/orange power Light to a blinking white light
Roughter Is a Xfinity Technicolor CGM4331COM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry and will do First timer here lol
- Mark as New
- Bookmark
- Subscribe
- Permalink
The CGM4331COM is a modem/router combo device.
It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
when you disconnect the XR from the xfinity device, are you able to log into it and access it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I'd try to do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry I gave up as I still could not connect or access the routers page at all. Plugged into the computer directly and having my xfinity powered off unplugged from the system I couldnt connect throught my phone app and threw my PC. One odd thing is I can only reset by powering off router push hold reset then power on and the router acts as discribed when reseting it, I canot reset it by just simply pressing the reset button and holding it down nothng happens no natter the length its held. It has to be turned off then press hold the reset button then power on and it seems to reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like the router maybe busted. I'd contact NG support to see if there is a RMA option available to you.
