Orbi WiFi 7 RBE973
Reply
This DFS channel is not allowed to use because the Radar was detected before. But I can't change it.
andym56
Tutor
The error message always displays, but I cannot make any changes to the wireless settings - it just complains about the radar.
That happens even when I try and disable the channel using DFS.
Any ideas?
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 11
Guru
Re: This DFS channel is not allowed to use because the Radar was detected before. But I can't change
Not sure what you mean by "that happens when I try and disble the channel using dfs"
DFS isn't something you can disable. You can use non-dfs channels. But if there's active radar, it isn't going to allow you to use dfs channels
Message 2 of 11
andym56
Tutor
I meant - I tried to disable the 5 ghz channel that was using DFS.
Simply selecting a non-DFS channel results in that error, so I thought I'd try that.
Whatever I do I get tat error message when I click on apply.
Message 3 of 11
Guru
Tried a factory reset and reinstall?
Message 4 of 11
andym56
Tutor
It's been like it for years, through many resets ans reconfigs. Always the same.
Message 5 of 11
Guru
what region are you?
Is there radar around you?
Message 6 of 11
andym56
Tutor
There is radar about 5 miles up the road at an army airfield. So I am prepared to believe DFS is out of the question. My problem is, I can’t select a non dfs channel because I get the error.
Message 7 of 11
Guru
what region are you in? (what region is on the router)
Message 8 of 11
andym56
Tutor
Sorry, Europe.
Message 9 of 11
Guru
do any of the 5ghz channels work?
List of WLAN channels - Wikipedia
Message 10 of 11
andym56
Tutor
For other access points, yes.
However, on the router neither of the 2 5ghz ssids are visible (in their factory settings). I cannot change anything on the wireless settings because I always get that error regardless of what I do. So I am stuck. I cannot try other channels.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 6892 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
