- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wake On Lan with R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wake On Lan with R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm running V1.0.4.30_1.1.67 and just tried it again after a fresh reboot (which resets the telnet listener). Worked again:
C:\>telnet 192.168.0.1
BusyBox v1.7.2 (2015-05-26 08:38:17 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Here's the MD5 of the telnetEnable.exe I'm using:
C:\>md5 telnetEnable.exe
MD5(telnetEnable.exe)= 90186d9b6dfe7f414af099f7663e53e4
I'm also directly adjacent to the Ethernet and used the MAC address of the Ethernet port of the R7000, as reported by 'arp -a'.
- Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
ViperGeek wrote:
Here's the MD5 of the telnetEnable.exe I'm using:C:\>md5 telnetEnable.exe
I'm not sure if this was obvious from the openwrt.org post, but the new syntax for new telnetEnable is:
C:\>telnetEnable 192.168.0.1 <MAC without colons or spaces> admin <admin password>
The old Gearguy/Geardog stuff is long gone (thankfully).
- Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Post above is recent, I am using latest telnetEnable.exe x.x.x.x mac
Firmware Version V1.0.4.30_1.1.67, but always getting
send failed: 10057
Tried all kinds of variations, mac with or with '-', ip without mac, old Gearguy ... no luck. mac ip verified with arp -a
My goal was to setup perm arp, to enable Wake over internet for various devices from the solution here http://forum1.netgear.com/showthread.php?t=90065&page=3
Any ideas on acomplishing this task in the GUI, or how to get telnet enabled on recent R7000 firmware?
Trying to perform this command:
# arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm
where x.x.x.x is the WoL destination IP address (not .255) and mm... is
the WoL destination's MAC address
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi cpufox.
You're running the exact version that worked for me in Post #28, so it's known to work in that release. The "send failed" error makes me think it's on the PC side, rather than the router side.
Two wild guesses off the top of my head:
- Are you running as Administrator in Windows?
- Can you try another NIC (network card) or even Wi-Fi?
Good luck. It should just "work" if you're running the latest version of telnetEnable.exe.
- - Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
BigBrosMo wrote: Anyone can tell me how to run the telentenable command from win 7 x64? It says its incompatible with 64 bit version. There is no link to a 64 bit version anywhere...
I'm running the new TelnetEnable.exe under Win 7 x64 and it works fine:
Did you download the binary from here:
https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe
Click View Raw to save it as a .EXE.
C:\UTIL>set PROCESSOR_ARCHITECTURE
PROCESSOR_ARCHITECTURE=AMD64
C:\UTIL>telnetenable.exe
Version: 0.4, 2015/02/12
Modified to work with newer Negear routers R7000 R7500 by insanid
Usage:
telnetenable.exe
C:\UTIL>
- Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
ViperGeek wrote: I'm running the new TelnetEnable.exe under Win 7 x64 and it works fine:
Oh man, thanks a lot Dave. I just right clicked on the exe and "saved link as". Didn't realize I had to go into it and click and Raw. You learn something everyday. All is good, arp entry added and WoL working across the interwebs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WoW has been working fine for months and suddenly stop working after a firmware update... So I 've been reading this post very carefully.
I did run the "telenetenable.exe" successfully but I still can't wake my PC over internet...
I set a static LAN IP
I opened a port for this IP
My no-ip ddns is running fine
So i'm lost... A little bit of help would be really nice 😄
- Mark as New
- Bookmark
- Subscribe
- Permalink
I finaly managed to get perm entry in my router's arp talbe for the computer I want wake up thru internet but it still doesn't work !
I'm sure that i'm forgetting something really stupid 😛
- Perm entry in ARP table
- Fixed local IP
- Port is open (at least it should be but this tool keep saying that the port is closed http://www.yougetsignal.com/tools/open-ports/ )
What am I doing wrong ? Is there a way to know where the magic packets are stuck ?
Thx ! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ViperGeek wrote:
Thanks for the quick reply. I actually had a reserved DHCP address for my WoL destination, but the ARP cache entry times out anyway.
However, I did find a solution:
Now I have PERM entry, confirmed via the 'arp' shell command, for the WoL target.
- Dave
Could you please post your solution again. It looks it was deleted.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mods,
Was my solution removed on purpose, or did a forum update perhaps wipe out my formatted text by mistake?
- Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
ViperGeek, I can see several posts made by you in this thread, and none deleted, so are you referring to a solution within this thread or another thread?
Working on behalf of Netgear
My name is Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Babylon5 wrote:ViperGeek, I can see several posts made by you in this thread, and none deleted, so are you referring to a solution within this thread or another thread?
Thanks for the response, Andy. My posts survived, but some of the juicy content was removed. For example, Message 25 had detailed steps for using TelnetEnable and creating static ARP entries, and Message 32 had possible solutions for another customer's problems that were seemingly removed. Finally, another user's quote of my original solution in Message 35 was converted to "...".
I'm OK with the edits if they were purposeful. It's just unfortunate that the most effective, viable solution was removed from this forum thread.
- Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dave,
I can see that those posts are clearly truncated, but even though these forums allow limited editing now, an edited post is tagged as ‘Edited’. I can only assume that text was lost in the transfer, but it seems too selective. Short of me asking everyone capable of such edits, we will have to wait and see if someone has an answer, but my guess is that no one had an issue with what you had posted.
My name is Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Riker.
Now that I've confirmed that the removal of my solution was a moderation, I'll try repeating it from memory (I was actually using this thread, bookmarked, to remember how to do it).
- Download TelnetEnable from here: https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe?raw=t...
- Open a DoS/Command Prompt on a PC directly connected to the same LAN and type 'telnetenable.exe <router-IP> <router-MAC> admin <admin-password>'
- Telnet to the router
- Type 'arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm' where x.x.x.x is the WoL destination IP address (not .255) and mm... is
You should then have a static ARP entry in your router. Set up forwarding of port 9/UDP to your device you want to wake and it should work.
- Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Babylon5 wrote:
Dave,
The original postings used [List] .. [/List] ie. numbered listing,. appears to be lost in transfer. Original postings have been updated with original content.
Kenneth
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dave,
thanks for posting your solution again. It works excellent for me.
One more matter. Is it safe to keep telnet console open? Because once you open telnet console to router there is no way to disable it till router is rebooted, but when router is rebooting we are loosing all settings.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're very welcome. I'm glad the solution worked for you as well.
There is a risk from keeping the telnet listener enabled, but the risk is mitigated by the fact that it's only accessible from the LAN side. Assuming you don't have a hostile local network and your LAN (including wireless) is fairly well controlled, you should be OK leaving telnet enabled. I'm unaware of a way to re-disable the telnet listener without rebooting.
- Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
This solution works perfectly. Thanks for sharing ViperGeek. The only issue is the new ARP PERM entry gets cleared every time the router is rebooted. Then I have to go back and re-do all the entries. This could be a hassle after a power failure. Are you aware of a way to save these settings permanently? I'm running an R7000 on 1.0.4.30_1.1.67 firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
@millertime23 wrote:Are you aware of a way to save these settings permanently? I'm running an R7000 on 1.0.4.30_1.1.67 firmware
Hi MillerTime.
Unfortunately, I've found no way to have these commands auto-execute on boot. I messed around with /etc/init.d, but I believe the R7000 uses a volatile filesystem in that everything is recreated based on config at startup. Nothing written to /etc, for example, will survive a reboot either.
- Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was worried that might be the case. Maybe a workaround would be to write a .bat file that will execute in windows task scheduler
