Orbi WiFi 7 RBE973
Reply
i need a mobile router as a mobile dj i need access anywhere also want to use in my cabin
thedjskeletor
Follower
Please help    i need a great mobile router
as a moble dj i need access to,the internet wherever i work  plus i have a field office  and a camper  possibly need one with an additional outside ariel
currently hace a tp link....its aweful    gets around 2mbps  on a good day   and there is zero help from their support line
i have tried constantly for 3 days   unable to connect with anyone   plus the other number they give you to call as a 24/7 access line   does not work     useless  is a good word to describe them
i have an
100gb /pm   ee sim
please help   with advice
gerry
when you want the best dj    i am your man
Message 1 of 2
davidm22
Re: i need a mobile router as a mobile dj i need access anywhere also want to use in my cabi
@thedjskeletor,
For mobiler router , i can suggest you to buy Netgear AirCard 797 Mobile Hotspot.. the basic features are the following.
  • Get 4G LTE and 3G Speeds Anywhere
  • Connect up to 15 Wi-Fi-Enabled Devices
  • Removable Lithium-Ion Battery
  • Up to 11 Hours of Use
I hope this will helpful suggestion.
canada post tracking
Thanks
David
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 644 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
