Orbi WiFi 7 RBE973
Reply
login problem
EdwardX
login problem
Hi , i recently bought a night hawk however i can not login into the router, tried www.routerlogin.net/com, and by mentioned IP adress but no results. please advice, i have read Q&A but this was not helpfull.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Accepted Solutions
EdwardX
Re: login problem
thank your for your help, however suggestions did not work,also the genie app is not able to connect i have decided to bring my router back to the shop and aks for refunding.
Message 5 of 5
All Replies
LeeH
Prodigy
Re: login problem
Message 2 of 5
Guru
Re: login problem
Other options are to try
Message 3 of 5
Re: login problem
Message 4 of 5
EdwardX
Re: login problem
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3594 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
