- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
nighthawk r7000 keeps losing connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently updated the firmware to V1.0.11.116_10.2.100 and it's dropping all connections about every 2 days. Home user. Cycling the power fixes the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: nighthawk r7000 keeps losing connectivity
I have the R700 and it is on frimware version 1.0.9.99_10.2.88 and I have been seeing the same issue for a few weeks now where we see a slow down and evenb disconnect from the router. In our settings you see the SSID of the router but when you try to connect it says the pwd is wrong and I have to type it in. It then tells me the password is incorrect even though it is correct. If I restart the router then it fixes everything but it seems to happen a lot more in the past couple of weeks.
