Orbi WiFi 7 RBE973
Reply
one of the users is gone after a power cut
msotelano
ReadyNAS 102
Hi: After a power cut the system restarted but one of the users (and all information/files) is gone. The user is in the list, also in the home directory but every user have also another directory/folder. The home directory is there, the user is still in the list and he can access to the nas. But the folder created to put their files and the files are gone. Everything else works fine.
Any ideas?
PD: When de system restarted after the power cut all the users were gone actually. But after turning the system off manually and turned back on all the users reappeared except one. Tried power the system off an on a couple of times but that user never appeared again.
Model: ReadyNAS-OS6|
Message 1 of 2
Accepted Solutions
Guru
Re: one of the users is gone after a power cut
Netgear has set up a community forum specifically for the ReadyNAS products. Most of the people who watch that forum are more likely to have experience with NAS products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/New-ReadyNAS-Users-General/bd-p/readynas-general
Thank you.
Message 2 of 2
All Replies
Guru
Thank you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 594 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
