Orbi WiFi 7 RBE973
Reply
"Captive Portal AC1750
random_543
Follower
Please help
Early today the breaker to the room that this wifi router serves tripped. So I flipped the breaker to restore power (this happens fairly often), after the power restarted I logged in to my laptop and it connected to my netgear wifi signal per usual. However, it now says my "captive portal is suspect" and I cannot use the internet.
Has anyone else had this problem? Suggestions would be welcome.
Also netgear wants to charge me $129 to put into a technical ticket which I think is total BS
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: "Captive Portal AC1750
> [...] it now says my "captive portal is suspect" and I cannot use the
> internet.
   "it"?  What, exactly, says what, exactly, when you do what, exactly?
> Also netgear wants to charge me $129 [...]
   Says who?  Whom you contacted how?
> [...] to put into a technical ticket which I think is total BS
      https://community.netgear.com/t5/x/x/m-p/2105479
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 542 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
