- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
r7800 and Powerline v1 2nd Port Complete Disconnect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
I have a new one for you, I bet. I have a r7800 and a powerline ethernet adapter (tk1000 ver 1, I believe). It has two ports on it, and I am successfully using the first port, no problems. I went to use the second port to get another internet connection and my 7800 completely freaks out. It attempts to add the port, but then shuts down, reboots, and completely loses all connectivitiy (web app, wifi goes down, ethernet goes down.) When I unplug the 2nd port of the powerline from the router, it comes back online, eventually.
I thought it could be the eth cord so I swapped that out. I've tried different ports on the router. Also, I even tried doing a complete factory reset. If I plug in the 2nd port to the router, it completely loses it. I just don't get it. The first port has been working fine for years.
Any ideas?
Thanks,
Josh
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Jbenhart wrote:
Don't I have have to plug both ports from one plug into the router and both eth wires (computer and tv) into the other plug?
Not in my experience.
When I use two-plug Powerline adaptors I have just one connection to the router – from a single-port plug. Then I can run two separate devces from the second two-port plug.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: r7800 and Powerline v1 2nd Port Complete Disconnect
What actual model number is the powerline adapter? I found a ton of adapters off the tk1000 version.
If its a dual plug ethernet model, you're not plugging both into the R7800? Correct? You should only need 1 powerline device plugged into the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is a TP-LINK AV1000 2-Port Gigabit model TL-PA7020 ver 1. Each plug-in has two Ethernet ports. Don't I have have to plug both ports from one plug into the router and both eth wires (computer and tv) into the other plug?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad to see you got it figured out with that dual plug in setup.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
