- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
r8000 LAN IP reservation issue with firmware 1.0.4.46
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a R8000 with latest firmware. My devices (wired and wireless) lost internet connection after I set a few (4-5) LAN address reservation.
Is anyone has the same issue ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved by doing the following steps
1. Reset to factory default setting
2. QoS : Disable
3. Smart Connect : Disable
4. Setup the some port forward and LAN IP reserve
5. Other features .. e.g. parent control, new security features ... OFF
I have not reset my router since 2-3 years ago, I susepect it cause the problem.
Above setting works without issue in last few days. I didn't test other senario (e.g. try to enable QoS..etc) since I already got what I want.
It will be great if I can have QoS and Smart Connect enable ... but I was too tired to perform any testing further.
Hope this help others who has the same problem.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2. QoS : Disable
