- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
readynas won't power up
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI,
I have an old readynas nv+ which came with 2 500gig disks. It is no longer poweriing up and I need to get access to the data. I have seen a second hand unit on ebay - if I buy the unit on ebay can I simply insert my 2 disks and everything will be fine ? Or are there problems with this approach, like the network configuration and other things that the ebay unit will have ? Would it be ok to get the previous owner to do a factory reset ?
I also noticed I can get a replacement power supply from a local pc parts company - can anyone suggest if this is a better approach ?
Lastly, I was trying to contact netgear support however this seems to be quite difficult for this old model - what is the best way to get some advice from a netgear support agent ?
Thanks Tom.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: readynas won't power up
Wrong forum. Try here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/bd-p/readynas-general
- Mark as New
- Bookmark
- Subscribe
- Permalink
Who knows? Have you determined that the power supply is the cause of your problem?
THese things use generic transformers. You may have one with the right specifications lying around,
Netgear provides 90-days free support for new installations. After that you have to pay.
Contact Us | Support | NETGEAR
Paid support is through Gearhead, but this place is free. As @microchip8 says, it helps if you start in the right place.
