Orbi WiFi 7 RBE973
Reply
unknown network
cvanzante
Tutor
unknown network
Hello.  After a failed firmware update, I successfully reset my R7000 and it now shows my firmware using V1.0.11.126 but it said no need for update at setup.  Using the Nighthawk app on my iPhone, I have accounted for every device on the network except for one item which is listed as "Network".  Using online searches, the Mac address shows 'private company'.  I have disabled this network and I am not seeing any change in existing devices.  Is there a means to isolate what this Network might be?  FYI: I did read through some of the threads but I didn't find an issue identical to mine.  Thanks in advance.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Accepted Solutions
cvanzante
Tutor
Re: unknown network
I am responding to my own earlier post.  After doing some additional online research, I came across an individual who mentioned a 'sleeping' Kindle.  I put mine on a different network and the phantom unknown device on my network disappeared.
Message 4 of 5
All Replies
Guru
Re: unknown network
Try a reset on the router again by pressing the reset button for 10 seconds then release. Connect 1 wired PC to the router and use a web browser pointed at 192.168.1.1 to setup the router from scratch.
Message 2 of 5
cvanzante
Tutor
Re: unknown network
Thanks for the reply Furry.  My PCs lack ethernet ports and I wonder if the HDMI port would work.  If I am unable to accomplish this task, am I OK with just leaving that network disabled? I am more interested in security than resolving the mystery.  Thanks again.
Message 3 of 5
cvanzante
Tutor
Re: unknown network
Message 4 of 5
Guru
Re: unknown network
Sounds like you found the cause.
For PCs with no ethernet abilities, you can install a USB to ethernet adapter on theses PCs.
Please mark your thread as solved so other will know.
Enjoy.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2040 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
