×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60 power adaptor
Mikeobrien
Follower
MR60 power adaptor
My girlfriends cat chewed through my MR60 power adaptor & I’m trying to get a replacement for it.  Unfortunately Netgear makes it impossible to get in touch with anyone that can help me.  I find it very interesting that you can’t email them to tell them what you are needing.
They apparently don’t really care about providing their customers with support.
Message 1 of 3
Accepted Solutions
Guru
Re: MR60 power adaptor
How bad is the cable. Most could be repaired, if stripped and twisted together and taped.
Look on Amazon?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 3
All Replies
Guru
Look on Amazon?
Message 2 of 3
Netgear does not sell replacement power adapters. Any generic transformer will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)
These things are pretty common, so first check to see if you have something compatible lying around.
Look at  the label on the device itself. The manual says 12V, 1A DC output the data sheet says 12V/1.5A power adapters.
Some web stores will even claim compatibility with Netgear devices. There may even be a retail outlet near you.
Some generic adapters come with a set of tips that will fit a range of different devices.
Generic adapterGeneric adapter
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Discussion stats
  • 2 replies
  • 773 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
