- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Setting up 2.4 network on MR 80, is this possible
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Setting up 2.4 network on MR 80, is this possible
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-W... 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure your TVs FW is up to date as well. Placement and distance between TV and MR or an MS is important as well. 5Ghz will out perform 2.4Ghz, if the devices are in good working condition.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ML47 wrote:
Not everything is 5g my Samsung tv is to slow or will not work with some streaming channels. Want to see if 2.4g will work better
Does your Samsung TV actually support 5 GHz. Most older TVs don't. It isn't needed to get the speeds required for TV streaming.
If the TV is 2.4 GHz only, then turning off 5 GHz will have no effect. The TV won't try to connect to a wifi source that it can't see.
If the TV has an Ethernet input, one way to beef up the connection with Powerline Ethernet. This turns the local mains network into an Ethernet connection between the TV and the router. It isn't just faster, it is also less liable to wifi interference.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
