Orbi WiFi 7 RBE973
Reply
8000P Show on Wifi list but has no Internet Connection
BeachNY
Tutor
I just installed the 8000P.  I followed the steps on the app.  I connected it to the back of my modem.  The Router is showing on the wifi list but has no internet connection. 2 questions, 1. how do i get it to connect to the internet and 2. does it have to be wired to my modem?
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 5
Guru
Re: 8000P Show on Wifi list but has no Internet Connection
1. yes it needs to connect by wire to the modem
2. that question alone makes me suspect your current modem isn't just a modem. What actual modem do you have?
Message 2 of 5
BeachNY
Tutor
I have a cable (TWC/Spectrum) modem.  It is a Technicolor TC8717T.
Message 3 of 5
Guru
That modem is a modem/router combo device.
it puts you in a double nat.
What is Double NAT? | Answer | NETGEAR Support
options? (only use 1)
1. put the ISP device in passthrough/modem only mode
2. put the netgears IP address in the ISP routers DMZ
3. put the netgear into access point mode.
Message 4 of 5
BeachNY
Tutor
Thanks for this info.  Once I figure out what it all means, I'll let you know how it goes.  Smiley Very Happy
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 448 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
