Orbi WiFi 7 RBE973
Reply
AC1750 R6700v2 disabled some features in Router mode
spialex75
Hello all.
I have Netgear R6700v2.
In router mode, I did not access to some features (they are gray out):
Internet Setup,
Wan Setup,
Lan Setup,
and more...R6700v2 disabled features.png Netgear is in ROUTER mode.
Why these features disabled?
Message 1 of 6
Accepted Solutions
spialex75
Re: AC1750 R6700v2 disabled some features in Router mode
I solved my problem.
Firmware version is 1.2.0.42_1.0.1
In front of router is modem TP-Link TL-WR740N (this modem was provided to me by ISP).
I called to ISP, and it told me to remove modem and to cable my Netgear directly to ISP. I did this, and now my R6700 works as router, and all settings are active.
Thanks.
Message 3 of 6
All Replies
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
Embedded pictures have to be approved by a Netgear moderator before they appear here. Files attached to messages are available immediately.
Message 2 of 6
spialex75
Thanks.
Message 3 of 6
That is why I asked you what the modem was in front of your R6700v2.
From what I can see, that is not a modem, just an old and slow router.
TL-WR740N | 150Mbps Wireless N Router (Discontinued) | TP-Link Australia
That would certainly explain why you had problems.
I guess there is some other box somewhere that delivers your Internet.
Message 4 of 6
spialex75
This is a equipment (TP-Link) that I've got from my ISP to browse internet... Smiley Sad
Message 5 of 6
Sorry, I have no idea what that refers to.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1350 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
