- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Bought a new NightHawk R7800 . Configuration portal is not accessible
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I bought a Netgear NightHawk R7800. It is connected to my Xfinity Router.
I have been trying to configure the router using the genie app on Phone, iPads, laptops (macs) connected on wifi or ethernet.
I have reset the router configuration to factory default.
I am still unable to access the portal.
i'm connected to the wifi of the router, and i get the following message:
You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again.
After a factory reset, i have tried connect to either 192.168.1.1 or 192.168.0.1, but the laptop is not able to ping these addresses and as a result i'm unable to configure the router.
Anybody has any ideas what i should be doing to fix that issue?
Thanks,
Nicolas
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for sharing the Information.
unfortunately it did not work.
i managed to fix my issue by disconnecting the R7800 from my comcast router, perform a factory reset of the net gear router, and configure it without the internet from an old mac through wired network.
Then I linked it to the Comcast router again, performed a firmware upgrade and now everything seems to be working fine.
i can now use the genie app and configure the router without anymore issues.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Bought a new NightHawk R7800 . Configuration portal is not accessible
Is it the r7800 to replace the other router as the main router or a access point and is the other router's wifi still active?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The r7800 would use as a access point and the main router will handle the ip address assigning 192.168.1.1 may be the same ip address as the main router.
Can not remember address to access the r7800 and configture it as the second in line right now.
Here is the users manual link http://www.downloads.netgear.com/files/GDC/R7800/R7800_UM_EN.pdf
Will try to recall the information the ip address and post for you later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
