- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Bridge mode with 802.11ad on Nighthawk x10 R9000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I was wondering if we can use 802.11ad on x10 to form a bridge between two x10 routers?
Thanks,
Mihir
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Depends if the other supporting AD router supports wireless bridge mode.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Bridge mode with 802.11ad on Nighthawk x10 R9000
Yes, if you are using the same R9000 as the main host router and AP and a 2nd R9000 in wireless bridge mode, it should work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the prompt reply.
If I use another router supporting 802.11ad, will the bridge mode work on R9000?
Thanks,
Mihir
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is no point in bridding AD as the range is not even 20% of 5ghz. It cant penetrate walls . it has to be in the same room more over line of site.
I guess your testing is only going to work if both the routers are in the same room line of site and you cant do a wired . But it too much costly affair .
You could get x4 7300 extender which will give you 1500+ connection rate which is equals to 1gbs/s
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bridding?
Possible to use these in close range with maybe one wooden wall in between and about 20 feet distance.
1500+ connection rate which is equals to 1gbs/s< This is only a connection rate between the 7300 and the connecting device. Does not mean data thru put will reach 1Gbs. Current wireless can't achieve that rate..yet. Maybe on a good AD connection. Again, also depends on client device and what it supports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is proven the wireless client reach 50% rate of transfer if in good qulity signal and more to that will be only if the distance and obstacle are minimal.
yes i believe with quad band connected client can achieve not near 1gbs but for sure 700+ if the connection rate is 1.5+gbps
But need to test it see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unlikely. 802.11ad requires unobstructed line of sight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. Will keep this in mind.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know what you find out.
@mondenath wrote:It is proven the wireless client reach 50% rate of transfer if in good qulity signal and more to that will be only if the distance and obstacle are minimal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mondenath wrote:yes i believe with quad band connected client can achieve not near 1gbs but for sure 700+ if the connection rate is 1.5+gbps
You must read to much SciFi. Netgear marketing does talk of "tri-band" routers with one 2.4 GHz and two 5 GHz radios, or one 2.4 GHz, a 5 GHz, and a 60 GHz radio.
Seriously think about "quad-band" (whatever that is) creating an awful amount of noise in the shared media called "air" just to replace a 20 ft US$ 6.50 CAT5A cable to the next room _just_ for a wireless bridge, killing almost any performance for other wireless in the area, including all your mobile device, notebooks, ...?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also big difference between connection rates and thruput rates. Completely different.
