- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can you add custom dnsmaq entry on the R7800?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Questions in the title. I want to setup a pi-hole on my network which my current router is too restrictive to allow. Going to replace it with an R7800 and the easiest method of setting the pi-hole up is to add a custom dnsmaq entry setting option 6 and the IP of the pi-hole. Can this be done on the stock firmware?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, but you need to enable telnet - go to http://192.168.1.1/debug.htm
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can you add custom dnsmaq entry on the R7800?
Doing it via telnet's more than acceptable. Many thanks for the answer!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Note that dnsmasq on NG routers is not used to hand out IP addresses; that is done by udhcpd for IPv4 and radvd + dhcp6s for IPv6.
