- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot Reset Parental Filtering for Bose Soundtouch Speaker
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model R8000, Nighthawk X6, Firmware 1.0.3.4 (Genie tells me it's the latest version), just updated Genie software as well.
I have parental controls enabled, blocking most "time-wasters", so to speak. Pandora is one of them. The speaker has connected successfully to a Netgear AP (older model, I haven't enabled WiFi on my R8000 yet). It connects just fine to the Internet. When I globally disable parental controls, Pandora shows up as an available service in the Bose app. When I re-enable parental controls, it disappears as Pandora is blocked. When I try to set the Parental Controls on the Bose to something other than "Default", it won't change. I can't set it to "None", "Low", "Minimal", or anything else. Bypass is not a possibility as I cannot install Genie on the Bose speaker.
I contacted Bose support and figured out it was the parental controls that was blocking Pandora. But now I can't reset the parental controls, so the issue is with the R8000.
Any suggestions on how to get the R8000 to change the parental controls on the Bose? Thanks.
-matt
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, Pandora is not blocked when it is set to None.
I solved the problem.
When I set it to Media Device, it gives no option to reset the level of parental controls. So I selected "Windows PC" and now it works. So despite the fact that it's just a speaker, I had to set it to "Windows PC" in order to take the filtering off. Weird, I guess.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot Reset Parental Filtering for Bose Soundtouch Speaker
Hi MattMatt,
Just to verify, even if the parental control is set to "None" still the pandora is blocked?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Pandora is not Re: Cannot Reset Parental Filtering for Bose Soundtouch Speaker
Hi MattMatt,
Glad it works now. Your solution might be helpful to others.
