- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DNS_PROBE_FINISHED_NXDOMAIN
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi,
My firmware version is V1.0.4.84_10.1.84, but i have the issue DNS_PROBE_FINISHED_NXDOMAIN , this error appear on all webpages on multiple browsers, it is a very uncomfortable problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS_PROBE_FINISHED_NXDOMAIN
Netgears aware of the issue. Not sure whats being worked on.
Some fixed it by simply enabling ipv6 and rebooting the router.
Have you tried this?
Others just downgrade a version of firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Thanks for your answer.
Yes i tried uploading 2 old versions but the router dont go back to these versions.
When you refer enable IPv6, this is the work around?
** internet Connection Type from "Disabled" to "6to4Tunnel", the rest I just left as automatic, applied and also rebooted the PC **
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
v.62 or v.68 are working older versions of FW that can be used.
- Mark as New
- Bookmark
- Subscribe
- Permalink
did the IPv6 work? I usually just use auto-detect and it works fine.
I do change my ipv6 DNS server as I use pi-hole but it should just auto-detect your isp's dns server.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I tried with "Disabled" to "6to4Tunnel", work fine around 30min then appear again the message DNS_PROBE_FINISHED_NXDOMAIN, before this IPv6 enable the error occurs inmediately.
Now i tried with the IPv6 Automatic Option, i choose this option, after apply changes appear in 6to4 Tunel, is like the router not refresh this change or choose 6to4 like automatic?.
regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its auto detecting that your setup is the 6-4 tunnel.
You might need to downgrade the firmware a version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Which version?
Firmware Version 1.0.4.76
Firmware Version 1.0.4.74
Firmware Version 1.0.4.68
Firmware Version 1.0.4.66
Firmware Version 1.0.4.62
Firmware Version 1.0.4.58
Firmware Version 1.0.4.52
Firmware Version 1.0.4.46
regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try the .76 or .74 version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
These versions work best:
I still saw DNS Problems on v.76 with mine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear Customer,
You have contacted the German-speaking NETGEAR Community.
We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
Kind Regards,
DamianM
NETGEAR Community
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I had similar DNS problems.
My solve/resolve tied back into ENABLING IPv6 under the advance settings. See my thread below
With latest version of the firmware V1.4.3.88_1.3.50 and factory reset.
Hope this helps you!
