Orbi WiFi 7 RBE973
Reply
Does the Nighthawk X8's Power Supply Support 240V (USA Model)?
charlesle
Tutor
Message 1 of 4
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Does the Nighthawk X8's Power Supply Support 240V (USA Model)?
This should be working perfectly.
We have one working in a remote office using 240V.
Message 4 of 4
All Replies
ElaineM
Hi @charlesle
Welcome to the community!
Yes you can. Just make sure that you use the same DC output of 19V, 3.16A.
Message 2 of 4
charlesle
Tutor
Thank you @ElaineM
As an U.S. expat working in India, I was planning to get a co-worker to bring the X8 for me next week. I have an India purchased universal power strip (made by Belkin), which uses a Type D (5A) plug as shown here:
http://www.worldstandards.eu/electricity/plugs-and-sockets/
I can plug your typical U.S. Type A plug into it and it works fine for all of my gadgets (MBP, work laptop, etc.)
Can you confirm if things will work properly? I am not sure when the X8 is coming to India, but the reason I'd like to bring one from the U.S. is so I am able to use it in my home when I return to the U.S. without having to hook up a power adapter.
Message 3 of 4
ElaineM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4930 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
