× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7000 can't ping its clients intermittantly
Dauhee
Hi,
I have an EX7000 with setup as an extender, relaying clients back to main wifi router.
Basically from wifi Main, I cannot ping clients on wifi EX7000 (this is intermittant), however when I connect to wifi EX7000, I can ping successfully. So I cannot connect reliably to devices being extended. I have changed routers and behaviour is the same, although seems to be varying levels of unreliability.
Has anyone ever had this issue and worked a solution?
Thanks
Message 1 of 2
Accepted Solutions
Guru
Re: EX7000 can't ping its clients intermittantly
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Message 2 of 2
All Replies
Guru
Thank you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 514 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
