Orbi WiFi 7 RBE973
Reply
Extend Range of CAX80
dcphillips
Follower
On Spectrum Cable with 400 mbps and looking for the most economical model that will get through a few sheet rock walls and approximately 30 feet away from the source.
Any advice is greatly appreciated, thank you.
Model: D6000|AC750 WiFi Modem Router - 802.11ac Dual Band Gigabit
Message 1 of 2
Re: Extend Range of CAX80
@dcphillips wrote:
...looking for the most economical model that will get through a few sheet rock walls and approximately 30 feet away from the source.
What are you asking for here? Help to find a wifi extender? What do you want to extend? The D6000 modem/router in your footer or the CAX80 Cable Modem Router in your subject?
Try plugging your needs into the filters on the product pages:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 749 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
