Orbi WiFi 7 RBE973
Reply
Guest wifi just does not work HELP?!! please
freebo99
Tutor
hi
not sure what the issue is...
guest wifi on 2.4ghz not tried other freqs just dont have the time...
done a factory reset still got issues,
latest firmware is installed
not sure it this is a windows 10 problem or the router, im guessing the router
before factory reset it was a nightmare to get connected to a hidden guest ssid
but you could sometimes after messing around with the ssid and password for a long time in the settings or the router.
but after factory reset you are able to get connected to the router but no webpages load just time out BUT if you open commandline and ping google.com it pings fine.
does not matter what web browser, firefox, chrome, edge all the same.
whats going on? anyone help?!?!
thx
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 224 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
