Orbi WiFi 7 RBE973
Reply
Hacked and locked out
krc141
Follower
Router R7000P, I was hacked and the person who did this changed the password and checked the box where I cannot go in and get the password to change it. I am completely locked out of my router. How can I get back in and why isn't this router more secure than this.
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: Hacked and locked out
> to change it. [...]
   Which box is that?
> How can I get back in [...]
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Factory Settings".
> [...] why isn't this router more secure than this.
   I doubt that anyone here knows exactly how you were "hacked", or the
firmware version on your router, so i's not immediately clear how secure
"this" might be.
Message 2 of 3
All Replies
antinode
Guru
> to change it. [...]
   Which box is that?
"this" might be.
Message 2 of 3
William10a
Master
Possible you could try a factory reset and reset up the router, if you were hacked and locked out you should be able to get back in to it.
I would change the name and passwords used just in case.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 8502 views
  • 6 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
