Orbi WiFi 7 RBE973
Reply
How do I setup a bridge mode on the NETGEAR R7000?
Ana2
Based on the instruction that came with my Netgear Nighthawk R7000 AC1900 Smart WiFi Router, I disconnected the router provided by my cable company and replaced it with my Netgear router.  Although the WiFi is working, I am getting intermittent service on my TV and the internet constantly drops off.  Upon reviewing reviewing the communities conversation it looks like I may need to set up a bridge.  How do I go about doing that?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
antinode
Guru
Re: How do I setup a bridge mode on the NETGEAR R7000?
> Based on the instruction that came with [...]
   _Which_ "instruction"?
> [...] my Netgear Nighthawk R7000 [...]
   Firmware version?  Connected to what?
   If you bought it new, did you try Netgear support?
      http://support.netgear.com/
> [...] Upon reviewing reviewing the communities conversation [...]
   The whole thing, or some particular parts, or what?
> [...] it looks like I may need to set up a bridge. [...]
   What, exactly, led you to that conclusion?  What, exactly, does "set
up a bridge" mean to you?
Message 2 of 5
What provides the Internet to these routers? There is usually a modem of some sort between the router and the outside world.
Most ISPs supply a modem/router to do that. You cant just remove that and use a router in its place. So what is feeding the R7000?
Message 3 of 5
Ana2
I followed the manufacturer's instructions that came in the box with the new router. I am using the cable company's modem but replaced their WiFi router with my Netgear 36 nighthawk R7000 router. It worked fine for a while but now my internet connection keeps dropping. After reading the various related issues other users had it seemed like I needed to create a bridge. Based on your feedbacks and since it is a new router I will be contacting their support group. Thank you all for your support.
Message 4 of 5
antinode
Guru
> the new router. [...]
   With my weak psychic powers, I can't see them from here.  Thus, I
don't know what you read, or what you did.
> [...] I am using the cable company's modem [...]
   With my weak psychic powers, I can't see it from here.  Has it a
maker and model number?
> [...] but replaced their WiFi router [...]
> like I needed to create a bridge. [...]
   With my weak psychic powers, I can't see what you read.  "seemed"?
> "set up a bridge" mean to you?
   Which part of "exactly" did you find confusing?
   Thanks for answering none of the questions.
> [...] Based on your feedbacks and since it is a new router I will be
> contacting their support group. [...]
   You might need to provide some useful information, there, too.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 612 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
