- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I am trying to upgrade my firmware for my router
- Mark as New
- Bookmark
- Subscribe
- Permalink
logging in router to verify security questions it doesn't like info they are the same response?????
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have forgotten the password, or the system has got its nickers in a twist, the only way to regain control is to reset the thing to its factory defaults. Then you can use the default login details.
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
See page 12.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
See page 12.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I am trying to upgrade my firmware for my router
Thank you for your response. Problem fixed. Crazy anser for the two questions shuld have been the same.
