- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is segmented network possible..??
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello all.
Can the Netgear Nighthawk AC2600 be configured so that the wired lan is separate/segmented from the wireless ip-range?
Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
As long as Allow guests to see each other and use the local network is disabled, then guests will only be able to access the Internet. Guests will be in the same IP range as other devices but the router will block access.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Is segmented network possible..??
For what purpose, to keep them apart from one another?
You could use the Guest Network facility for Wi-Fi which you could isolate away from your LAN
I hope this helps
Modem: Vigor 130 | Routers: R7800, R8500 & R9000 | ISP : Plusnet Unlimited Fibre Extra
Powerline: PLP1200x4 PL1200x6 | WiFi Extenders: PLW1000 & XWN5001
Switches: GS105Ex2, GS105Ev2, GS108Ev2, GS305
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes, to keep them apart from one another.
When I switched on "Guest Access" my laptop got the same IP that it had when I had secure-WiFi turned on. Not sure if turning on "Guest Access" really segments networks.
I am presuming this device does not let me allocate two sets of IP-ranges one for each band.
Oh well, I guess this is not possible on this appliance then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, that may work.
Thanks for the suggestions and the responses.
